Discussion topic: Connection issues
This message was authored by: JOD10
Connection issues
My WiFi connection is constantly breaking. Any apps on the tv are crashing every few seconds to a few minutes. There's potentially a general issue as a friend a block away on sky is also having issues. However, mine breaks regular & needs to be reset (every half day or so) which I don't think should be normal
Re: Connection issues
@JOD10 while it is possible it is an area wide issue it is more likelya local issue.Check the lights on your hub when you lose connection https://www.sky.com/help/articles/hub-lights-explained-start as they help to diagnose if its an issue with the connection rather than simply an issue with the wifi signal from the hub to the device.
