Discussion topic: Connection issues
Message posted on 07 Aug 2025 07:35 AM
Connection issues
Internet box keep disconnecting every few minutes non stop is there a problem in my area or just sky internet in general
Message posted on 07 Aug 2025 07:39 AM
Re: Connection issues
If it was a nationwide problem the forum would have gone into meltdown.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
