Discussion topic: Connection issue
This message was authored by: ahmad10
Connection issue
Internet light is off.
i have a socket accepting a broadband cable. The phone line cable seems to be below it but I cannot physically put anything into it. I cannot seem to connect to internet. Is there a technical support line??
This message was authored by: Me134
Re: Connection issue
If I'm reading that correct, you're trying to plug in your router & phone? If so just select your router on the help pages here and follow the video.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access with MLO enabled, main Deco hardwired to Max hub
Avatar for ahmad10
No I I'm just describing the type of socket I have. I have just a router connection socket. Below it the phone line part of the socket is just a rectangular white area but not recessed out to allow any phone socket input.
by the way I am not trying to get a phone line I just need the net to work.
