Discussion topic: Connection issue
This message was authored by: tolester
Connection issue
Can someone check what's going on with the internet in CT11 postcode area. Been off for over 4hrs with the message
There's an outage in your area
We're working on getting you back up and running. It usually takes a couple of days to fix things like this but might be sooner.
Internet is usually spot on with very few hiccups. Is this a larger area issue or a more local one.
be interested if someone can check.. don't need this going on for days.
Re: Connection issue
@tolester Posting on the Forum you are not talking to Sky, so you will get no check or no answer to your question!
