Discussion topic: Connection is intermittent
Message posted on 13 Apr 2025 07:20 PM
The tv has been going on and off for 3 days now . We cannot watch any programme in full . Phone has no internet connection at times too
Message posted on 14 Apr 2025 07:24 AM
Re: Connection is intermittent
@Amandaw2 do the lights on the hub change when you lose connection? If they do there is probably a line problem that needs checking out which msybe possible by using the service checker in the My Sky app or by calling Sky.
However it couldcsimply becpoor wifi coverage in your home. Streaming video requires a good stable signal so will show up poor wifi. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
