Discussion topic: Connection has dropped
This message was authored by: Chokka
Hi , I unable to connect my broadband , it is showing hat the connection has dropped redirecting us to connection diagnosis screen. Could you help us to fix this issue ?
Re: Connection has dropped
@Chokka
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
