Discussion topic: Connection has dropped from my router
Message posted on 10 Dec 2025 04:29 PM
Message posted on 10 Dec 2025 06:02 PM
Re: Connection has dropped from my router
@Jonhan2 See if any off the two help options below are off any use!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
and/or
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
