Discussion topic: Connection has dropped and won't re-connect
This message was authored by: Tiberius75
Connection to wifi dropped about 8pm, tried restarting the router when it didn't automatically re-connect, but still no wifi. Done a status check and apparently everything's working as it should be and even when the router is flashing orange, the status check is stating we're connected at 149Mbps. How can that be?
Re: Connection has dropped and won't re-connect
@Tiberius75  When did you do your last service check and how long has the connection been down for?
