Discussion topic: Connection had dropped
This message was authored by: Rachel69
This message was authored by: Claire1789
Re: Connection had dropped
I've got the same issue, I'm stoke on trent
@Rachel69  & @Claire1789  Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Avatar for Rachel69
Level 0 icon
Hi I have found out through SKY customer service that my area Internet is down for the day
@Rachel69  Glad to see that you found out it was not just you.
