Discussion topic: Connection DOWN
This message was authored by: iwaddo
Connection DOWN
Hi
Can anyone please tell me the likely cause of the error below.  It is happening most weeks and started when we switched to full fiber. We've had a new cable, router and ONT and both Openreach and Sky there is nothing wrong!! (note I changed the IP address to x's)
syslog: WAN IPV6 UP
syslog: Lease renewed 3600 ip xxx.xxx.xxx.xxx
syslog: [3739008.410000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
syslog: eth3.1 - WAN link DOWN.
syslog: DHCP lease expired from server. Connection DOWN.
syslog: [3739011.432000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
syslog: Voice IP Connection Down
syslog: Voice Disconnected
syslog: No lease renewal received
The workaround is to restart the ONT and router.
Any help appreciated.
This message was authored by: mae-3
Re: Connection DOWN
@iwaddo
If the ONT PON is green then it is likely a known issue that SKy are working on to solve currently, it is a failure at the TCP/IP layer 3 when the physical link ONT PON light is solid green, and effectly loss of the IP connectivity to Sky backend servers.
Avatar for iwaddo
Level 4 icon
Re: Connection DOWN
Thank you.
So there is nothing that can be done to alleviate the problem?
Sky just seem so 'could not careless' about it.
Re: Connection DOWN
@iwaddo
Whilst Sky are looking at the issue you'll have these outages but Sky are activily investigating the issue because it is a global issue impacting many customers, so you aren't alone, once the issue is solved it will be fixed for all experiencing the random outage issues. Unfortunately, there isn't a timescale for how long it is going to take to fix it.
Avatar for iwaddo
Level 4 icon
Re: Connection DOWN
I wonder why they are not being honest with me.
No one mentions a known issue, I just get the same nonsence checking routines, offers of a new cable etc. None of which will fix it.
Thank you for your help
