Discussion topic: Connecting products
Message posted on 22 Oct 2024 05:54 PM
Connecting products
I'm struggling to add my Nest thermostat to the wifi & also join an Arlo doorbell chime unit.
My emails also no longer preload content since changing to a Sky Broadband router
can anyone assist with these issues?
Message posted on 29 Oct 2024 10:15 AM
Re: Connecting products
Hi @SimonDur
You may need to disable the 5ghz band on your Sky hub temporarily. Do you have a black or white Sky hub?
As for your emails, try switching off Sky Shield & disabling iCloud relay if you have an Apple device.
Message posted on 29 Oct 2024 10:35 AM
It's white
Message posted on 29 Oct 2024 10:44 AM
In that case the setting for you will be in the My Sky app under advanced router settings
