Discussion topic: Connecting my Sky Router with a TP Link EAP 110 outdoor access point
Message posted on 03 Jan 2024 05:15 PM
I've installed a TP Link EAP 110 Access point externally, to cover reach a Ring security camera. How do I link this to my Sky router?
Message posted on 03 Jan 2024 05:16 PM
Re: Connecting my Sky Router with a TP Link EAP 110 outdoor access point
I have a TP Link EAP 110 access point which I want to use to extend network to an external Ring camera. How do I do this please?
Message posted on 03 Jan 2024 05:36 PM
Given the name suggests Enterprise Access Point, that may not be ideal hardware for a domestic setup.
A quick look at the TP-Link support site suggests as a minimum you need to install management software on a computer to administer the AP.
Message posted on 03 Jan 2024 05:44 PM
To me it appears the Omada range is intended to be a competitor for similar but longer established SME business-grade hardware from Ubiquiti.
https://www.tp-link.com/uk/solution/omada-sdn/
Message posted on 03 Jan 2024 05:53 PM
You'll need to ethernet cable it to the Sky router, as wireless extending will not work Sky equipment is completely proprietary.
