Discussion topic: Connecting WiFi Printer
This message was authored by: Karen300
We have the new Sky Max Hub but we are unable to connect our Epson ET-2710 Printer.   I have the printer right next to the router and it still won't connect any ideas?  All other devices have connected ok.
Re: Connecting WiFi Printer
@Karen300 see the link Epson ET-2710 - Search
If it does not pan out, then use the MySky app and see were the Max hub is at with the WPA3-T setting and reduce to WPA2-PSK and you may just have to switch off the 5Ghz band as a temp measure to get the printer connected, remember to switch it back on once you do get the printer connected to the sky Max Hub!
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
