Discussion topic: Connecting Printer
Message posted on 19 May 2025 07:37 PM
Connecting Printer
Hello
my first post.
I have only been with Sky about 3 weeks. All is ok but I just can not get my Canon TS3150 to connect to my router.
I have tried all I can think of and all I can find online. This printer will need to be used via my phone and iPad
my computer is no longer used.
Any ideas please
Message posted on 19 May 2025 08:16 PM
Re: Connecting Printer
Message posted on 19 May 2025 08:24 PM
From what I can see it's just called a Sky Hub. Stands upright .
basic package
thanks
Message posted on 19 May 2025 08:38 PM
@Kerabo Do the video link setup for the WPS, just make sure the printer is close to the hub.
Message posted on 19 May 2025 08:44 PM
I have tried WPS WITH THE PRINTER 6 feet from the router and nothing ?
Looking on my iPad it shows the printer and then says no internet and the signal has a line through it.
could the frequency of the modem be wrong for the printer.? Everything else vinnected
thank you
Message posted on 19 May 2025 08:48 PM
@Kerabo You can try it to see, as you do not say which hub you have, see the link below. White hub then temp disable the 5ghz band and look at the wpa mode, set to wpa2-psk if you get that option.
Message posted on 19 May 2025 08:53 PM
Thank you
sorry but I can't find in my contract eBay hub I have but in the link you sent it's the hub on the right.
I will try to go into the hub setting tomorow and get back.
