Discussion topic: Connecting Hive to router
This message was authored by: Bshe
Message posted on 06 Feb 2025 09:55 AM
I have just changed from BT to Sky bradband and cannot connect my Hive to the router as it has no USB port. I therefore cannot operate my Hive.
Can anyone help? Thanks
Find out more
Message posted on 06 Feb 2025 04:07 PM
Re: Connecting Hive to router
Hive does not require a USB connection to your broadband hub, only ethernet. You can power the hive hub using any other USB port you might have available or perhaps a USB adapter plug.
I am NOT a Sky Employee
