Discussion topic: Connected without Internet.
This message was authored by: Julian01
The router lights are on but is no Internet connection .
Re: Connected without Internet.
@Julian01
Avatar for Julian01
I did all i could, lights are still green no Internet no WiFi,the app ses there is no issue at the area or adress .
Have you tried rebooting your broadband hub at the mains ?
If this doesn't fix it what was the resukt of the broadband line test ?
Avatar for Julian01
I did restart it ,no results still same problem, connected, no Internet connection
@Julian01 there is a fault where all of the lights on the hub are green but no data passes.This is caused by an issue at Sky's end the recommended fix is to power down the hub for at least an hour and reconnect which should give you a new connection. Given these servers handle in excess of 6 million lines the occasional glitch is almost unavoidable.
