Discussion topic: Connected with no Internet
This message was authored by: Dionne13
That's all my WiFi says connected with no Internet. When I use thr service checker it says everything is fine and I should be good but it's not and I need the WiFi for work today.
Re: Connected with no Internet
@Dionne13
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
