Discussion topic: Connect
This message was authored by: MW14
Connect
Netflix everytime I try to put a film on it won't go by 20%
Re: Connect
@MW14 if other apps work normally its an issue with the Netflix  app. If you are using a Sky Stream puck use the refresh apps in thecsystem settings to clear the fault.
