Discussion topic: Connect hub to extender
Message posted on 22 Jul 2026 09:25 AM
Hi all.
Just joined up with Sky broadband a week ago & trying to connect my TP Link Extender to it.
Pressing the WPS on Sky Max Hub for about 3 seconds DOES not make it flash blue for me to then press the WPS button on the extender to link them.
Any suggestions?
Message posted on 22 Jul 2026 04:07 PM
Re: Connect hub to extender
Hi @Raj57
What is the model of your TP-Link extender? It might be incompatible.
Message posted on 22 Jul 2026 06:50 PM
Hi James
The model is RE450
Message posted on 22 Jul 2026 07:50 PM
Hi James
It's more to do with the Sky Hub light not turning blue after pressing the WPS button despite all the solutions saying this is the easiest way to connect.
I also can't connect to my water softener which requires the WPS being pressed.
Message posted on 22 Jul 2026 07:54 PM
@Raj57 you need to press and hold the WPS button until t he light starts flashing blue which rakes up to 10 seconds. Hold it too long though and the bu resets with acflashing green light.
Message posted on 22 Jul 2026 08:34 PM
Hi Chrisee
I have held the WPS button down for 9 seconds with no change in the hub light. Articles say more than 10 seconds and you are likely to reset the hub.
On my old BT router I pressed it for a few seconds and the light changed.
Sky technician said WPS may not work on occasions for pairing up.
Message posted on 24 Jul 2026 01:48 PM
Hi Chrisee
Today Sky reset my security level to WPA2 & then waited for about 10 mins.
This allowed the WPS button then to light up to blue after pressing for about 4 seconds.
This enabled me to connect to both the TP Link Extender & the water softener.
Regards
