Discussion topic: Connect a Sky Max Pod via a ethanet cable to sky max router
This message was authored by: Adrian3i4909
I have a ethanet cable in the garage running from my sky max router to the sky max pod. As its too far away from my house. I can't get the sky pod to connect via the cable. Can / how do I do this. Alternatively what other devices can I use to improve my WiFi signal in the garage.
Re: Connect a Sky Max Pod via a ethanet cable to sky max router
@Adrian3i4909
You may be better off using a dedicated WiFi AP on the end of the cable
I am NOT a Sky Employee
Avatar for Adrian3i4909
It all seems to work fine now :0
