Discussion topic: Concerns about Hive connection
Message posted on 19 Nov 2024 09:55 AM
I have Sky broadband on order, but I have read that the Sky Max hub has problems when it comes to connecting Hive and other Smart systems. This worries me, as I don't want to be left without heating once I have changed supplier. Does anyone have any advice or information about this? Thank you
Message posted on 19 Nov 2024 10:43 AM
Re: Concerns about Hive connection
As long as you disable Sky Shield you shouldnt have any issues connecting Hive as the hive hub connects to the router via an ethernet cable, not WiFi, therefore it wont suffer with any WiFi signal incompatibility.
Message posted on 19 Nov 2024 10:54 AM - last edited: 19 Nov 2024 10:55 AM
Issues reported in this forum are typically:
The Max Hub uses WPA3 WiFi encryption by default, which some IoT devices don't support
It's not possible to permanently split and rename the 2.4Ghz and 5Ghz bands on the Max Hub as it was on previous Hub models
Some users find there's less wireless coverage within the property after switching to Max
