Discussion topic: Compatibility issues.
This message was authored by: HIGHLANDERS68
Message posted on 19 Feb 2026 09:52 AM
Hi as anyone else experienced compatability issues with Hive app. Its plugged into router. However nearly everytime you try to connect too Hive app on WiFi it doesn't connect. Done all the usual turn on and off, and updates on apps, but problem still exists. Was working fine with my old broadband provider.
Message posted on 19 Feb 2026 10:29 AM - last edited: 19 Feb 2026 10:30 AM
Re: Compatibility issues.
@HIGHLANDERS68 Start here with the hive system support, there are a few different modules, but the Ethernet connected hub works fine on a sky connected hub for sure on the black SR203 sky Broadband Hub!
