1
This discussion topic has been answered Discussion topic: Chromebook Internet connection
This message was authored by: SandraMcw
Unable to get Internet connection on my chromebook although connected to WiFi
Re: Chromebook Internet connection
@SandraMcw if other devices are connecting correctly check the network settings on the Chromebook. Ideally set the unit to get the network details automatically from the hub. If setting manually set the gateway address to 192.168.0.1 and the subnet mask to 255.255.255.0 the chromebook needs an IP address between 192.168.0.2 to 192.168.0.254 but if manually using an IP,address you should reserve that addresses on the hub.
