Discussion topic: Checking broadband settings
Message posted on 08 Mar 2024 02:28 PM
I have been trying to check / update my broadband setting (PG, 13 etc) for over a week now. However, when signing into my account I am continually told "sorry there has been a problem ", as below.
Has any one else had a similar problem, is there a solution or work around?
Thanks.
Message posted on 08 Mar 2024 03:20 PM
Re: Checking broadband settings
@J+Parnall Have you tried doing this on a PC if you have one in a browser?
Message posted on 08 Mar 2024 03:52 PM
Yes, I've tried both a desktop and laptop. Same message on both.
Message posted on 08 Mar 2024 04:36 PM
@J+Parnall If you are unable to change it and you are the account holder give Sky a call and listen through the voice prompts and they should be able to set it for you. Just dial 150 on your landline.
