Discussion topic: Changing to a asus router
This message was authored by: Cheshireprowler
Im trying to swop out my sky hub for a new asus rx58u
im on fttp
following the instructions from asus ive got as far as plugging everything in.
i was expecting a quick internet detection page to pop up but it hasnt.
however what  has popped uo us a page asking for
my username and password for my internet connnection information.
apparently provided by my isp (sky)
how or where do i find such infor
i appreciate your help.
Re: Changing to a asus router
@Cheshireprowler
For fttp in the uk :-
Change the connetion to automatic ip
This may be up the client identifier (option 61) field and you should enter
anything@skydsl|anything
If client identifier (option 61) doesn't appear then you need to set up your sky router and ethernet the asus to perform firmware updates until it doesn't update anymore.
Then remove the sky hub and ethernet the asus to the ont and enter the client identifher as above
Avatar for Cheshireprowler
Thank you so much worked a treat 👍🏼
