Discussion topic: Changing max router settings
This message was authored by: Op+Sol
I have installed a new Max router and need to select 2.4g to re install my smart devices. I have tried the access using admin and then either sky or the router password and neither give me access to the gateway
Re: Changing max router settings
@Op+Sol with the new hub the settings are managed in the My Sky app not the web interface. You cannot split wifi bands as you can on older routers instead find the Turn off WiFi screen in the Advanced settings for the hub and turn off the 5GHz band then connect your devices then turn the 5GHz band back on and the devices should stay attached.
Avatar for Op+Sol
How do i access via My SKY?
Avatar for Op+Sol
On Broadband and talk settings  Broadband shield, Advanced Security and Advanced settings are all greyed out saying come back when your broadband has been activated? My broadband is running all beit not as good as before.
