Discussion topic: Changing hub password
This message was authored by leodavinci This message was authored by: leodavinci
Has anyone used the change wifi hub password instructions on 192.168.0.1  via admin/sky login with success.
I have been tring via Edge to log in all morning but it wont let me.
Re: Changing hub password
@leodavinci
Try a device etherneted to the hub using chrome
leodavinci
BTW it is reporting this address as not secure with invalid license
leodavinci
ummm dont have any ethernet cables ..
@leodavinci
I would ignore that as the internal lan ip never goes outside of the lan onto the wan.  There should be a way of bypassing the message
Just try a different browser if the actual login is hanging . Otherwise go ahead on the basis that dispite the warning the connection is secure
