Discussion topic: Change wifi settings
This message was authored by: HOGGLE1
I need to change 2.4 and 5g wifi names as can't connect ring door bell to 5g.
Re: Change wifi settings
@HOGGLE1 You can only do that with the older sky hubs called split bands, the sky Max and onwards do not allow for it anymore, so you have to temporary switch off the 5Ghz signal, connect the device once connected switch the 5Ghz back on! The two links below show and explain.
Split Sky WiFi bands
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
