Discussion topic: Change wifi Broadband
This message was authored by Yogeskumar This message was authored by: Yogeskumar
Hello sir or madam I used wifi last 11 months is good But now sum web site not opening in wifi connection. And I use my mobile data that time web site open. Like this web site (Apne TV. ) can you check please. What's problem for my Wifi Broadband. Thank you
Re: Change wifi Broadband
@Yogeskumar you are not talking to Sky by posting in the forum you will have to call them to get their help.
It is unclear if your issue is simply poor WiFi or the site not opening due to a block. I can access www.apne.co over my own Sky conection and I cant see that Sky's Broadband Shield would block that site but check the setting in the My Sky app just in case.
