3
This discussion topic has been answered Discussion topic: Cannot connect to internet although WiFi showing as connected
This message was authored by: Najrana
WiFi is showing as connected on devices but not connecting to internet. Have tried rebooting with no luck.
Avatar for Najrana
This message was authored by: Najrana Answer
Re: Cannot connect to internet although WiFi showing as connected
Many thanks for your reply. I did all the above, and kept getting a screen saying there are issues and then when I went to troubleshoot it showed all was working fine. But still no internet. Rebooted a couple more times and repeated the process. Eventually internet came back, but have no clue what changed..
@Najrana   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Avatar for Najrana
This message was authored by: TJ107
Contact number for a technician please
