6
This discussion topic has been answered Discussion topic: Cannot connect Wifi Max broadband installation. Am I missing something?
This message was authored by: KatieS1
Received text from Sky that our Wifi Max Broadband is now ready - so at our end we are to install.  Tried all the instructions and plugged in the correct cords (I think) - still not connected.
What am I doing wrong?
Was on hold with Sky to try to work it out -  the call disconnected after being on hold for 1.5 hours.  Not happy.  Without wifi and I need it fixed
Please help
This message was authored by: peter-marlow+1966 Answer
Re: Cannot connect Wifi Max broadband installation. Am I missing something?
Have you gone through  the  setup on the  my  sky app
P c marlow
P c marlow
Avatar for KatieS1
Yes, did that.
Avatar for KatieS1
Are we confused re which cord to plug into where?
@KatieS1 Ethernet cable, has 8 pins on plug, Wan port 4 on back of router, to ethernet connection on ONT from openreach if this is an FTTP install.
Otherwise purple cable from dsl on router to master socket of telephone wall connection.
There is a help on sky if you need it, document sent with router does not always show what to do...
Link added to get you there
Setting up your Sky hub | Sky Help | Sky.com
@KatieS1
It's quite likely that data won't actually start flowing until midnight at the end of the activation day.
Avatar for KatieS1
Escalated to an engineer now. Tried multiple times 🙁
