This discussion topic has been answered Discussion topic: Cannot connect HP 2700 printer
Message posted on 17 Feb 2025 10:11 AM
Hi
I have an HP 2700 deskjet printer, It was working fine on my old provider however not on the SKY connection. It just coming back with the error cannot find printer. disconnected from internet is the message on my screen.
Message posted on 17 Feb 2025 10:13 AM
Have you gone through the process to set it up as if it was a new printer as this will need doing now you have moved to Sky.
Message posted on 17 Feb 2025 11:49 AM
Re: Cannot connect HP 2700 printer
Hello
Yes, I have however during the setup the printer doesnt seem to connect to the new WIFI.
Message posted on 17 Feb 2025 11:57 AM
This is literally even when the wifi router and the printer are next to each other. Not sure if the issue is that the printer is not compatible to detect high wifi speeds?!
Message posted on 26 Feb 2025 01:17 PM
Having same problem but can't remember how to set up printer to broadband. Need someone to talk be through all the steps please.
Message posted on 02 Apr 2026 06:55 PM
Have just joined Sky Broadband and I cannot connect to my HP 2700 printer
I have made sure we are on WSP 2 ? instead of WSP3 security
How do I split the two frequencies or is there another way of connecting?
Thanks Lindsay
