2
This discussion topic has been answered Discussion topic: Can you have two Sky Broadband boxes on one property?
This message was authored by: CookieHouse
Basically, I have one Sky box near the front right of my property. It reaches most of the house perfectly, but I have an office now set-up in the garage, which is the same side of the property, but further away, with about 3/4 walls separating it from the box. It's also outside the property, and so it doesn't reach the garage at all. I expected this.
I'm quering to see whether to see if an additional Sky box on the same package/ an extender/ booster that can replicate the same speeds we meet in the house, in the garage, or whether to install a LAN cable from my box inside the house, over to the garage. This would be about 16/18 feet away.
Looking to do this promptly. If there is a way to get the wifi box/ one installed to the garage, can someone explain the process exactly for me.
Thank you for any responses
Re: Can you have two Sky Broadband boxes on one property?
@CookieHouse
Ethernet cable is always preferable.  Sky won't help with supply or installation of that or any other method of reaching an external building though: such locations are specifically excluded from the various 'guarantees'.
@CookieHouse
This message was authored by: Osmond
Running an Ethernet cable from the front of your property to the outbuilding will give you the fastest and most reliable connection. What I did was place a small gigabit switch next to the hub at the front, then ran a network cable along the outside of the house to the back, where it connects to another switch inside the outbuilding.
