Discussion topic: Can’t get WiFi Max
Message posted on 08 Jun 2025 03:40 PM
Can’t get WiFi Max
I currently have Sky Full Fibre Gigafast, but every time I try and order WiFi Max I keep getting told it's not available. I have tried online, and on the phone. Any idea on how to get it?
Message posted on 08 Jun 2025 03:43 PM
Re: Can’t get WiFi Max
@Gary+Birmingham There is a stock issue for both the Sky Max hub and the Sky Max Pod's at present, so that may be the complete and only reason at present for the NO your not getting it!
There may be a shortage of the sky max hub at the minute
Have you moved from sky q to sky stream recently?
Message posted on 08 Jun 2025 03:46 PM
@cookiemonsteruk Thanks, forgot all about the Q restrictions on the Sky Max, will not do that again.🙄👍
Message posted on 08 Jun 2025 03:52 PM
Shouldn't be a restriction anymore however if the transfer from sky q was done manually there may be remnants of sky q on the system. These need to be deleted before it becomes available. Thats the situation i am in but i don't see any benefits at the minute
Message posted on 08 Jun 2025 03:54 PM
I have requested an update on stock availability of the sky max router and pods from community mamagers
Message posted on 08 Jun 2025 03:58 PM
@cookiemonsteruk And i also completely forgot about that too, see what being away for the year does to the old memory cells.
Message posted on 08 Jun 2025 04:01 PM
Its amazing what i can drag out of long term memory after 4+ years oracle/superuser+
Message posted on 10 Jun 2025 07:08 PM
Yes I have just moved from q to stream. How do I get Sky to fix it?
Message posted on 10 Jun 2025 07:16 PM
You need to call sky on 150 from your landline or
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
And say that there may be a conflict of the old sky q install and sky max. Ask them to refer the case to the back office team to see if there are any sky q remnants conflicting with sky max and to remove as necessary
