Discussion topic: Can’t connect
This message was authored by: Bobyjon
Can’t connect
Says WiFi is too weak to connect to my ps5 even though it's in the same room and was connected last night and all day today
Re: Can’t connect
@Bobyjon reboot the  hub as that should cause it to find the least congested WiFi channel tomuse. Assuming the hub is out in the open not stuck in a corner on the floor you should get fast WiFi innthecsame room but keep the console and hub around a metre apart.
