Discussion topic: Can’t connect to one device
This message was authored by: Darcyvic
Message posted on 21 Jan 2025 09:26 AM
One of my devices is saying unable to connect but there isn't a fault with device as it connects to any other network and the WiFi works on my other devices
Find out more
Message posted on 21 Jan 2025 09:27 AM
Re: Can’t connect to one device
Do you have a white or a black Sky Hub?
Message posted on 21 Jan 2025 12:48 PM
It is white
Find out more
Message posted on 21 Jan 2025 12:58 PM
With a white Max Hub you may need to reduce the wireless security level from WPA3-T to WPA2-PSK using the Hub settings in the My Sky app.
