Discussion topic: Can't connect a device
This message was authored by: MartinB_
Hi I can't connect my son's playstation it saying ever week connection or SSID might be incorrect
Re: Can't connect a device
@MartinB_  To game you need a reasonably fast stable data feed which means WiFi is never the best choice. If running an Ethernet cable is impractical investigate buying a powerline networking kit which is often a good second choice assuming your home's mains wiring is reasonably good. Otherwise consider improving your home WiFi by getting extenders by paying monthly for Sky's WiFi Max bundle and asking for one or by buying your own WiFi set up which can be cheaper.
