Discussion topic: Can’t change sky WiFi password
This message was authored by: Dan+Lovelock
I type 192.168.0.1 in browser and i see sky website i press WiFi then as I try to sign in i type Admin then my sky WiFi password on my hub box i press enter then the website crashes and not loads it deletes the text i wrote in the sign in box so nothing loaded to the next page. I have tried few times I also used different devices and called sky support no changes
Re: Can’t change sky WiFi password
@Dan+Lovelock
Are you using an Apple device? If so try with a non-apple device, ideally connected via ethernet
I am NOT a Sky Employee
This message was authored by: Dave+Moyse
That is further than I get, the page just crashes.
@Dan+Lovelock the account name is always admin not Admin the password on the older hubs is sky (note lower case s) the wifi passcode is used on the upright SR203.
