4
This discussion topic has been answered Discussion topic: Can I get Superfast 80
This message was authored by: FunkyGibbon
I'm with Sky on  Superfast 35.  Openreach claims I should be able to get 61MB download, aslo confirmed by BT and PlusNet.
When I login to mySky and try and upgrade broadband Superfast 80 is not an option.  Have Sky stopped offering this?
TIA
This message was authored by: cookiemonsteruk Answer
Re: Can I get Superfast 80
@FunkyGibbon
Your line can only handle 26Mbps quite why openreach would say otherwise  i have no idea
@FunkyGibbon
Could you enter your full address below and post the table and notes after removing your address from the image
Avatar for FunkyGibbon
I guess I'm stuck at 35
@FunkyGibbon
This is what openreach states:
@cookiemonsteruk Thanks for your help.
