Discussion topic: Camera’s keeps cutting out
This message was authored by: Jeani1
My wifi keeps kicking off my camera's & only my camera's. Use to work fine but now every night my camera's go offline. I have two different brands of camera's too so its not the camera's themselves playing up
Re: Camera’s keeps cutting out
@Jeani1
Does your broadband go down at the same time because if it does it could be overnight maintenance taking place.
If it still down later then the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Avatar for Jeani1
No its not always the same time & i done the tests already & it says its all good. Most of the time They come back on later but i sometimes have to reset them as if ive changed my wifi. Like i said its only in my two different sets of camera's everthing else is not affected by it, its strange.
@Jeani1 Are you using Sky Q or sky mini's!
Avatar for Jeani1
Im using Sky Q
@Jeani1 Has the sky Q been set to go into low power sleep mode for eco settings.
Using the standby settings | Sky Help | Sky.com | Sky Help | Sky.com
