This discussion topic has been answered Discussion topic: CAT5e Cable
Message posted on 10 Jun 2024 11:42 AM
What colour is the CAT5e cable (not the wires inside the cable) that Sky uses internally?
Message posted on 10 Jun 2024 01:40 PM - last edited: 10 Jun 2024 02:13 PM
If you are thinking of the cable to the ONT from outside, that's an optical pigtail and is a much thinner grey/white.
Left to right that's power (white with white barrel jack) , ethernet (black with yellow RJ45 plug) and optical pigtail (white with green SC APC plug)
Message posted on 10 Jun 2024 11:53 AM
Re: CAT5e Cable
Are you referring to an ethernet patch lead supplied by Sky for connecting between an ONT and a Sky Broadband Hub / Max Hub for FTTP broadband, or the bulk cable which Sky (very rarely) deploys to solve Q television issues?
Message posted on 10 Jun 2024 01:13 PM
Re: CAT5e Cable
Hi
Just the cable from the ONT and a Sky Broadband Hub that runs along the skirting board.
We have a door frame to go around and if the cable is not white it is going to look ugly
Message posted on 10 Jun 2024 01:37 PM - last edited: 10 Jun 2024 01:57 PM
Re: CAT5e Cable
I believe Sky bundles a 1.5 metre black patch lead, but you can replace it with one of your choice in colour and length.
Note that Sky doesn't 'install' that cable: the customer is expected to plug it in. The one they supply certainly won't go round a door frame so you'd need to source your own anway if you want the Hub that far away from the ONT.
Message posted on 10 Jun 2024 01:39 PM
Re: CAT5e Cable
@vipsana if I remember correctly its black with yellowcends but given you can buy ethernet cables in any colour and length you like cheap,y it is pretty easy to get what you want
Message posted on 10 Jun 2024 04:16 PM
Re: CAT5e Cable
Hi
Problem solved. Thanks to everyone for the help.
