Discussion topic: Buffering is disjointed
Message posted on 11 May 2026 09:22 PM
My problem is that the signal is too slow and while watching the football everything is disjointed. The sound is heard before the action and sometimes the picture appears in slow motion. It is completely spoiling the viewing. Please help !
Message posted on 11 May 2026 10:25 PM
Re: Buffering is disjointed
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
