1
Discussion topic: Broken grey cable purple end
This message was authored by BigJD This message was authored by: BigJD
Hi
where can I get a replacement broadband grey cable that has a purple connector that goes in the back of the broadband hub. My cable is broken.
thanks for your help
This message was authored by TimmyBGood This message was authored by: TimmyBGood Answer
Re: Broken grey cable purple end
@BigJD
Typically that's an RJ11 plug at the modem end.  If it's going into a wall socket at the other end, that may be RJ11 as well (in a microfilter or filtered faceplate) or a BT jack.  You'll find cables like these widely available online.
@BigJD
