Discussion topic: Broken Routing Tables @ 2.120.14.17
Message posted on 21 Jun 2025 02:55 PM
Hello
I'm having issues with connectivity to certain European servers.
I did some quick tests and it appears that `2.120.14.17` - one of your servers is dropping 100% of packets, indicating incorrect/poor routing on your end.
Here are the results of ping and pathping to the server i'm having issues with.
PS C:\WINDOWS\system32> pathping 94.250.199.40
Tracing route to 94.250.199.40 over a maximum of 30 hops
0 DESKTOP-SMN3GQ6.Home [192.168.0.50]
1 SkyRouter.Home [192.168.0.1]
2 2.127.238.243
3 2.120.14.73
4 2.120.14.17
5 fra-eq6-pr1.zet.net [103.246.249.30]
6 * * *
Computing statistics for 125 seconds... Source to Here This Node/Link Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0 DESKTOP-SMN3GQ6.Home [192.168.0.50] 0/ 100 = 0% |1 2ms 0/ 100 = 0% 0/ 100 = 0% SkyRouter.Home [192.168.0.1] 3/ 100 = 3% | 2 17ms 4/ 100 = 4% 1/ 100 = 1% 2.127.238.243 0/ 100 = 0% | 3 18ms 3/ 100 = 3% 0/ 100 = 0% 2.120.14.73 3/ 100 = 3% | 4 --- 100/ 100 =100% 94/ 100 = 94% 2.120.14.17 0/ 100 = 0% | 5 35ms 6/ 100 = 6% 0/ 100 = 0% fra-eq6-pr1.zet.net [103.246.249.30] Trace complete.
"Pinging 2.120.14.17 with 32 bytes of data: Reply from 2.127.238.243: Destination net unreachable. Reply from 2.127.238.243: Destination net unreachable. Reply from 2.127.238.243: Destination net unreachable. Reply from 2.127.238.243: Destination net unreachable. Reply from 2.127.238.243: Destination net unreachable. Reply from 2.127.238.243: Destination net unreachable. Reply from 2.127.238.243: Destination net unreachable. Reply from 2.127.238.243: Destination net unreachable. Reply from 2.127.238.243: Destination net unreachable."
Pings to 2.120.14.17 fail with ‘Destination net unreachable’, but replies from 2.127.238.243. This is breaking my connectivity to [94.250.199.40]. Please check routing between these nodes.
Regards,
Jack.
Message posted on 24 Jun 2025 10:24 AM
Re: Broken Routing Tables @ 2.120.14.17
This is entirely normal, some routers on networks will not respond to pings but will still pass traffic. If it was dropping say 50% of packets then this would likely indicate an issue, however 100% drop just suggests its not configured to respond to pings.
