Discussion topic: Broadband weak signal
This message was authored by: AW6567
Since starting with Sky for broadband my ring security light and camera continually go offline and if I am home and try to reconnect it keeps telling me there is a weak signal or the camera doesn't even recognise the Sky network. I had no issues with camera with previous broadband supplier and am concerned about my home security.
Re: Broadband weak signal
@AW6567  Do you have broadband boost or Sky max as part of your broadband package?
Avatar for AW6567
After posting my comment I got a message from Sky offering me Sky max for an additional £4 s month which I agreed to but doesn't seem to have made a difference and my phone doesn't seem to be able to stay connected either. No problems with I pad or kindle 🤦‍♀️
@AW6567
Have you actually had a router and/or booster delivered?
I am NOT a Sky Employee
Avatar for AW6567
No nothing new delivered yet.
@AW6567
Well it wont have made a difference yet then. If you've taken WiFi max out then you should get the white Max hub if you havent already, it then also entitles you to claim booster pods to improve coverage so you'd need to contact Sky to claim these.
