Discussion topic: Broadband upgrade
Message posted on 02 Sep 2025 11:04 AM
Broadband upgrade
Hi,
I have recently upgraded from superfast broadband to full fibre 500, do I get a new hub to go with it as I have the 1 that came with the superfast package? Thanks.
Message posted on 02 Sep 2025 11:11 AM
Re: Broadband upgrade
Ideally you'll get the white sky max wifi6 hub sr213
Message posted on 02 Sep 2025 11:27 AM
- Thanks, I havnt received any notification to say that thats the case
Message posted on 02 Sep 2025 11:38 AM
Do you have the black upright sr203 at the minute ? There had been stock issues for a while with the sky max hub but that seems to have been rectified. Fingers crossed 🤞
Message posted on 02 Sep 2025 11:45 AM
That is correct, the black, upright (always falling over) sr203 hub. Do they send out automatically per chance?
Message posted on 02 Sep 2025 11:50 AM
You should have been notified on signing up which hub you would get. It may be in your sky account or my sky app . Any new hub is despatched to be with you up until the day before activation
