Discussion topic: Broadband stopped working
This message was authored by: SunitaAsher
My broadband has suddenly stopped working.
Internet and voice light is turned to red
Re: Broadband stopped working
@SunitaAsher
It could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
