Discussion topic: Broadband not working
This message was authored by: Sherilee
CR4 area broadband not.working, your service checker on the app says everything is working...but it's not. Have switched it off and waited and switched it back on. Still not working and what was all green lights is 3 green and orange in the middle.
This message was authored by: Sellers
Re: Broadband not working
Same here in SM3.
This message was authored by: Barry1977
Same in sm4 area
This message was authored by: Winkyng
Same here. In CR4 as well
This message was authored by: Tee0911
Internet not working
I live in the CR4 area and the internet is not working. I have switched off the Internet box for 30 seconds the power light and connection light is on green but the Internet light is on orange.
i've checked on the app and it says everything is working normal.
This message was authored by: Ineedinternet
Re: Internet not working
Same same same. CR4 area not working
If it's happening at the time you've posted it's possibly maintenance related. This is done overnight to minimise disruption as most customers are asleep. If it's not back up by the morning (7am), use the below link to check to see if there are any problems or outages nearby https://www.sky.com/servicechecker
If there aren't any then try running the line test here https://www.sky.com/help/articles/broadband-diagnostic-start
Once completed, if it reports back that all is good click on 'broadband' to run an updated test.
If you get amber or red you need to follow the on-screen instructions.
This link providers information about the coloured lights on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
