Discussion topic: Broadband speeds
Message posted on 14 Apr 2025 03:36 PM
Broadband speeds
our current speed test is coming out at 1 MPS and there is almost constant buffering
Message posted on 14 Apr 2025 04:49 PM
Re: Broadband speeds
@DavidG7 run the service checker in the My Sky app to see if the speeds to bthe hub are the issue. If they are the app should offer further help.
However many times this is down to poircwufi signal in your home Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
