Discussion topic: Broadband speed
This message was authored by: Leeshovlar
Broadband speed
Is it normal for the Internet download speed to drop as low as 12mbps on the 1st day of activation, when the minimum should be 600mdps.
Re: Broadband speed
@Leeshovlar no its not normal but to exclude it is not simply dodgy WiFi either run a test on acdevicecconnected by Ethernet or failing useca deviice in the same room as the hub but roughly 2 metres from it. If the issue continues call Sky innthe morning.
